Mi sony m4 aqua comenzó a apagarse y encenderse solo, lo único que hace es iluminarse en blanco con el logotipo de Sony y enciende bien cuando le preciono la parte de la tapa donde esta el NFC y cuando enciende no prende el wifi,datos, bluetooh y estando en reposo se apga o usandolo, me dijeron que se desoldo un poco el microprocesador ¿qué puedo hacer para encenderla o necesito una reparación?
My sony m4 aqua started to turn off and turn on by itself, the only thing it does is to light up in white with the Sony logo and it lights up well when I preciono the part of the cover where the NFC is and when it turns on it does not turn on the wifi, data, bluetooh and being at rest is apga or using it, I was told that the microprocessor desoldo a little what can I do to turn it on or do I need a repair?
-GT
it's the battery.You'll need to either buy another one or give it to a repairman to put it.Hope it helps.Good luck!
