My subwoofer just dosent work on TV, Blu-ray,or CD. I have cleared the amp of all settings, but it won't let me select 5.1 only 5.2 or 5.2.1 it seems to default on 3.2.0 in fact 5.1 isn't even on the list.
Help Please!
Hi there,
Have you checked that you have the latest firmware?
Best wishes,
Sean
Hi Sean
Iv just updated to the latest firmware, and on re-calibrating the speaker setup the SW is there but very weak.
Hi Pascale
Done that, no help from Sony they said take to an engineer. Thanks for your reply.
Abadando
