Missing key on Xperia E5 keyboard
JohnnyS
Hi, again. Sorry to come back with another query so soon after the last one! The Sony Xperia E5 online user manual makes reference to a "12!?" key. But I can find no such key on the keyboard of my E5. Can anyone explain why that is, please?
Thanks in advance.
JohnnyS
Jonas
Master
Hi @JohnnyS,
I'm sorry for the confusion. Slightly_frowning_Face
The picture in the user guide is wrong, and is showing a screenshot of the Xperia keyboard that we used to have in our previous models, that is why you can't find the button on your Swiftkey keyboard.
I would however have been strange if you could see the button on the keyboard in your phone! Slightly_smiling_Face
Thank you for finding this out and I will make sure to forward this error in the user guide internally.
I'm sorry for the inconvenience and let me know if there is anything else I can assist you with! Slightly_smiling_Face
7 REPLIES 7
Uliwooly
@JohnnyS
could you share the page of the user manual with that reference?
JohnnyS
Thanks,uliwooly. Here's the link http://support.sonymobile.com/gb/xperiae5/userguide/Swift-key-overview/
Scroll down to "To change the Gesture input settings"
Uliwooly
@JohnnyS
They are referring to 5
JohnnyS
Yes, but my keyboard does not have such a key!
Jonas
Master
Hi @JohnnyS,
JohnnyS
Ah, that explains it! Many thanks for the info, Jonas.
Jonas
Master
You're welcome, and thanks again for finding this out! Slightly_smiling_Face
Have a great day!
