I have set my xperia e phone to text to speech and can not turn it back off anyone got suggestions please
Topic edited by Rickard
I see your problem is already solved but in case anyone else encounters this and is not able to scroll in menus you need to use two fingers to scroll if you also enabled explore by touch under Settings -> Accessibility.
Thank you Rickard!!!
Your solution worked!!!
Its very easy to disable talk back. if you are unable to reach upto accessibility button. Do this.....
1.Just keep your double fingers on screen to scroll up and down.
2.to select any app touch 1+ 2 times every time to select any app
If problem persist.... Pl call me... removed by alexdon (INDIA)
swipe with your 2 fingers to scroll down
i cant use my phone because of the talk back button please help me
Use two fingers to drag down notification bar,you need to tap two times to select an option.Go to accesibility-talkback.
You could swip down or up in settings and go to accessibility WITH TWO FINGERS.
The solution to this is, use 2 fingers on the screen to scroll, 1 finger scrolling doesnt work, accessibility is intended for blind people I think, so to avoid accidental navigation they made it multitouch. no need to reset the phone, hope this helps
for scrolling down double tap and scroll down then it works.
