How do I transfer contacts from the phone to the SIM-card ? I wish to have all my contacts on the SIM-card if I change telephone.
Regards,
Olle
Hi @Bello2,
You can transfer the contacts to your SIM card if you start with opening up the Contacts application in your phone > press the 4 lines in the bottom right corner of your screen > Export/backup contacts > SIM card.
@NeoBeum, The Xperia E has a "menu" key instead of a task key, so it looks a bit different in the phones that don't have the 3 dots!
Let me know how it went!
Thanks, but the problem is that I can´t find the sign (triple dot options) on my phone (Xperia E-dual) can you give me additional info ?
Regards,
Bello2
Long press contact. Or do what ever it is to get your options menu. You have physical buttons right?
My android 4 was a galaxy. Before that was x10 mini in droid 2.3. I forget things.
I could transfer to sim on both, and I can now on a z5c, so you will be able to, it's there somewhere.
Take a screen cap of your phone book, and filter out all the numbers, and post up the pic of the UI, I can't find any online
Hi @Bello2,
@NeoBeum, That is correct. The left button on Xperia X10 Mini will open up a menu in the applications that have one!
It's the same on most phones (Xperia Arc S is another example) that have "hardware" buttons just below the screen.
I knew it had to be somewhere
