Can anyone tell me how to print from W630 Digital compact camera on a dpp-fp50?
Hi maccalad, welcome to the Sony Forums
Normally you would connect the camera to the printer's USB port with a suitable cable. In the camera settings, locate [USB Connect] and choose [Pictbridge]. With the printer switched on, the camera should be in playback mode and you can initiate printing from the on-screen prompts as you review your images.
Have you tried this and it's not working?
Mick
Mick
The DSC-W63 does not support PictBridge but of course it is also possible to print images from the camera:
1
connect via USB: the camera has to to be set to mass storage mode. As the printer has no build in LCD it is not possible to get a preview on the printer and also the camera will not show images for selection. But you can connect a screen to the printer ("TV mode")
If this is not available you have to memorize the image numbers you want to print.
2
The printer has memory card slots (SD and MS) so you can print directly from storage card.
you can download the full manual of the DPP-FP50:
