XF9005 WiFi disconnect after Oreo
Tigermad1
The above tv keeps getting the WiFi not connected pop up after installing Oreo. Lots of people reporting same issue on other forums and other Sony TVs too. Not sure if connected but most people with XF9005 have a Sky Q hub. Can it please be looked in to.
77 REPLIES 77
stewartgordon4
i have had the same e-mail at least six times in the last three months it looks like a stock e-mail that sony send out as every e-mail is worded the same
pauegert8
Hi.
Well it's been a number of weeks since I disabled ipv6 on the lan side.
My TV is connected via the ethernet cable and I have not had one drop out!
It might be my imagination but my other devices seem to be more stable as
well. My phone is roaming between access points more reliably and I haven't
noticed any other problems.
pjo456
As I've said, I connect my VPN over IPV6, hence I need it
stewartgordon4
sony are now saying that you dont have to disable vp6 as the fault is on the tv
pauegert8
Yes Sony agree the fault is on the TV but the current version of Android
can't cope with ipv6.
This is why they're suggesting its disabled until a future update fixes the
problem.
Dont hold your breath though as they said this 3 updates ago!
Pete0001
I've updated to PKG6.6555 and  it seems even worse for getting the message and dropping wifi.
Pete0001
So Sony have told me to disable IPV6 on the LAN side last week on my sky router. Since I've do that I've had no wifi drop out or wif not connected message which is good. I have told them this and all they said was we are pleased it has solved the problem and disabling IPV6 wont cause any issue/malfunction. No mention of a future update.
pauegert8
This is the reply I received:-
Dear Mr xxxx
Thank you for your recent Email and for raising your feedback.
First and foremost, We would like to apologize for any unintended
inconvenience for any service that has not met your expectations to date.
In reference to your enquiry about your Sony KD-65XF9005 TV, we can confirm
that our engineers are aware of the software issue you have been facing and
it is being investigated currently we also plan on releasing a fix in a
future software update.
However, we cannot provide any further information at the moment, as the
investigation is still ongoing.
Should you have any further questions, please feel free to reply to this
e-mail.
Thank you for your enquiry.
Yours sincerely,
