Firmware v6.6555 now available in the UK
Ryanm1701
Just downloaded and installed via USB. no issues after installation.
From Sony Support site
Benefits and Improvements from the latest update
  • Improves the TV’s responsiveness when switching on from standby
22 REPLIES 22
Mrhappy37
I agree, it is very distracting. Try the factory reset as it looks like it might have solved the problem on mine, but only time will tell.
MrBrianPotter
Ok may give that a go later 😬
Mrhappy37
Post your results as it would be really promising if you get the same result as me 👍
