Sudden Battery Drain and Hot Phone after Software Update
dbman2023
Recently, my Xperia 1 IV updated the systems software to 64.1.A.0.913 and Support to 5.10.2
Since then, the phone has had terrible battery drain and the phone gets hot after using any app for a few moments.
It gets so hot, you can't touch it.
This only started after the system update.
How can I fix it?
It's UK, on O2 contract.
2 REPLIES 2
jumpsuit
Hi @dbman2023
Currently the only way to fix this is to either perform a factory reset or to do a software repair
using the Xperia Companion application on a PC.
jumpsuit
We have members now reporting that updates 61.2.A.0.460  and  64.1.A.0.929
are fine with no issues, which may save people having to restore / software repair.
