Z5 Premium not turning on
RISOLTO
BlazeAwesome
Visitatore
My Xperia Z5 Premium won't turn on.
I've pressed and held the power button. Didn't work. The hard reset is not working. I tried pressing the off button near the SIM and tried turning it on again. Didn't work.
Also when i hook it onto the charger the notification light doesn't light up. PC Companion isn't recognizing it either.
Please help!
51 RISPOSTE 51
wayasome_hadi
Visitatore
ty man that worked for me , io thought my phone was dead for and my ultimate sone phone was dead over night for no reason .
thanks alot man i hope u hear something good soon in your live
alhadi.
Anvir
Visitatore
Hi, experiencing same problem. just gone through your discussions and possible solutions. Tried everything but still not working. My warranty is over and I guess this is it for this phone 😕
misha365
Visitatore
Our local Sony distributor apparently does not repair Sony mobile phones. What are my options?
ALedalum
Visitatore
Thanks, you saved my phone! Grinning_Face
Rizkps
Visitatore
how the trick to get my z5 premium back to life?
Hitman2
Visitatore
Thank you, it worked
Guissepe
Visitatore
Hello, I live in rural Alaska and do not have local support. My phone will not turn on.
Madhurao
Visitatore
My Sony Xperia z5 premium was not booting up, pressing power and volume key together for 15 seconds made it boot again , thanks for the solution
minga
Visitatore
Thanks, power and volume up also fixed my same issue of no response to any buttons or charging, where the reset button didn't fix it.
Dimed
Visitatore
Now 2019 in November, I'm still using this phone and the trick works just now..Thanks
