September 2013
September 2013
Hi frenz, got a prob w my ZL. Body become hot when I play games and during charging.... Plz help.
September 2013
September 2013
Make sure to close all BG apps...
Go to Settings > Apps > Running ( and check if any third party apps are running, Stop it )
Also for testing your device you can boot in safe mode and check charging...
To enable safe mode
- Turn off the device.
- Press and hold down the power key
until the phone vibrates.
- Wait until the Xperia™ logotype disappears.
- Press and hold the volume down key. The device then restarts in safe mode.
Note: To exit safe mode, restart the device.
3 REPLIES 3
September 2013
September 2013
While playing games its normal, long time gaming will leads to excess heat...
Heat while charging needs to be considered, please check any background apps are running...
September 2013
September 2013
Ok, but how to check any running background apps ?
September 2013
September 2013
To enable safe mode
