Not able to update the apps
deepak_chaudhar
I was facing an issue of phone getting locked while making calls.
So I tried to repair it through PC Companion.
After I was done I restored the backup.
Since my 3g plan got expired I disable data transfer.
Now if I try to update my apps through wifi am getting following message for all the apps.
I tried after enabling data transfer but didn't work.
Uliwooly
if my suggestion doesn't work (clearing Play store cache > restarting your phone ) then try this
settings > accounts > google > delete your account > restart your phone > re-add your google account.
Don't forget to give Kudos
11 REPLIES 11
Uliwooly
I can't see the picture, what does the error say? do you have any taskiller or antivirus? on you PC could you access play.google.com?
deepak_chaudhar
Message says
Update for "YouTube" could not be downloaded due to an error.(Error while retrieving information from server.[RPC: S-5:AEC-0)])
I have McAfee which came with it.
Dont have any task killer
When i check MyApp it says i have 7 updates.
Uliwooly
try this
1) settings > apps > all > play store > uninstall apps and clear cache > restart your phone >
if that doesn't work then
2) uninstall mcafee ( you don't quite need an antivirus) > restart your phone > try again
also how much free internal storage do you have?
shihstouch
Enthusiast
Hope you have enough memory...
Hope your internet is working properly...
Clear cache from Google Play Service and Google Play : Go to Settings > Apps
disconnect WiFi then switch of your phone, switch back on, turn on Wifi try updating now...
Uliwooly
deepak_chaudhar
I have 3+gb free memory.
Internet is working as I can browse through google and other sites.
I will try as suggested by you.
Uliwooly
if that doesn't work you could
1) repair your phone with either PCC or SUS (I doubt this will work )
or
2) wait as it could be a Google's server issue
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget the Kudos
deepak_chaudhar
One doubt. Do i need to remove all the apps.
shihstouch
Enthusiast
Also kindly check your Time & Date. Before proceeding... Sometimes this also cause problems in updating...
No need to remove apps, jus clear cache & clear data of play store...
