I have removed the Smart Connect function for when the phone is placed in the DK28, but still the phone wants to start either "daydreams" (or whatever it's called in English, I'm using Swedish settings on my phone) or my alarm app (Gentle Alarm).
How can I remove this function, it's not available in Smart Connect, I have removed all preset functions.
Cheers,
Chris
Seems like there's some sort of over-ride function in Gentle Alarm, even if it's set to "do nothing" when placed in dock, it causes the phone to ask for an action. With Gentle Alarm uninstalled, phone works as it should.
Go to Settings > Apps > All > ( Search for Smart Connect, Clear data and cache )
Try if this helps...
Thanks, but none of these instructions worked.
Tried both, first clearing data/cache, then checking that daydream was switched off, which it was.
I've tried removing the docking action from smart connect, and after that, since it didn't work, set up a new action that should run when phone is placed in dock without anything starting, but the phone still tries to start either gentle alarm or daydream when docked 😞
I've also made sure that no setting in gentle alarm makes it start when docked....
