camera bugs in ZU
HtetMyatSoe
camera bugs in ZU
I bought the Xperia Z ultra yesterday..... It makes me amazing features & I'm also really happy to got this amazing device... but It's 8 MP camera is really bad quality comparing with my old Xperia 10... Slightly_frowning_Face   xo many noise in back & front camera..   I don't know it's not included flash... Slightly_frowning_Face    Can you guys improve camera quality with software updates???? if not, i will change another device....
Uliwooly
try this
manual > change white balance and metering
23 REPLIES 23
Uliwooly
based on all other Xperias Sony doesn't quite improve the camera that much with updates, my suggestion is since the Z Ultra doesn't have flash that you take your pictures in well lit areas.
HtetMyatSoe
I dun means like this... We can't take good photo in dark place bcoz there is no flash in the back camera... It's not mainly error.... Even under the good lighting, the camera produce a photo with noises & it doesn't show reality colour... for eg. I took the white colour wall photo, but it produce yellow colour instead of white... Slightly_frowning_Face
Uliwooly
which camera settings do you have?
HtetMyatSoe
all settings are same with Xperai Z... I captured with superior auto...
Uliwooly
try this
HtetMyatSoe
Thank you!! Colour is OK with your suggesstions... but how can i reduce noise??
Uliwooly
could you post some pictures where you can see the noise, if you use burst mode it tends to reduce nosie
HtetMyatSoe
how to take screen shot??
LondonCalling
No Screenshot option in power menu, means now you have to take screenshots by the combination of “Power + Volume down” button.
