Hiya guys just wondering if anyone has any knowledge if the Sony bravia kd75ZH 8K TV will be getting any VRR software update to coincide with the PlayStation 5 getting the VRR software update. As it stands when I try activate it on my tv
It states TV doesn't support VRR which I thought very strange considering the TV is a 8K premium model. I know the ps5 didn't come with VRR and the latest software update installed it and Sony are applying the software update to some of its TV's . I just haven't heard if the ZH8 will be getting the update to. Thanks guys for all your help.
Hi @Josoap
Lol not as ancient as me 😉
You're welcome 👍
I made some official enquiries for you just in case but unfortunately there aren't any plans for the ZH8
to receive a VRR update.
Hi @Josoap
Yes you're right, your model doesn't support VRR.
I can't find your model mentioned in any planned updates either.
If I hear anything I will get back to you.
Which TV models support features that are specified in the HDMI 2.1 standard?
https://www.sony.co.uk/electronics/support/articles/00246472
Thanks a million jumpsuit. The funny thing it has hdmi 2.1 in the 8k hdmi port . It think Sony forgot they made this model 😅 I only have it since last October so it's not like it's ancient like me. Thanks again pal
Hiya Marino thanks for your reply. I just seen in the link you sent , the TV I have is a 2020 model, ZH8 , but the funny thing is it has hdmi 2.1 . So a bit gutted a software update won't be coming anytime soon . Thanks again for taking the time to reply cheers pal
Sorry typo it was October 2020 when I purchased it ,so in TV the terms it probably is ancient like me 😅.
Thanks again pal
Hi @Josoap
You're welcome 👍
Thanks again for taking the time to look into it. Just my luck 😭.
Cheers pal
@Josoap, yes unfortunately this model doesn't support the VRR yet 😞 you can also take a look on this link about the HDMI 2.1 features: https://www.sony.co.uk/electronics/support/articles/00254857
Thanks for your reply piscine. Yeah it doesn't look like a software update will come. Very disappointed as it has hdmi 2.1 port and it was a premium TV at just under €7,500 and all these TV's getting the VRR update are only half the price. I'll seriously reconsider buying a premium product from Sony again. But BIG thank you for taking the time to reply cheers pal 👍
