I read a question on this forum asking if the xa ultra was compatible with wireless charging. The person that answered said that the phone did not support it and that it could be enabled with accessories. Does anyone know of or have a list of any of these accessories that can be used to "convert" my phone into a wireless charging supported device?
you can buy something like this
micro usb qi wireless charging receiver card
or
Duracell Powermat Ring Wireless Charging Adapter
or
Thanks a bunch!
