I had a problem with my Sony Xperia XA. The headphone jack does not register my headphones. I have tried different headphones and that didn't work. I used the app "SoundAbout" to test if the problem is a software issue or hardware issue. Since it did work while using the testing app, I assume it is a software issue. The chat support man told me to try safe mode. This didn't work. He then told me to try using the software repair function. This came up with an error screen every time. I also cannot backup my device as it freezes while backing up "other". I hope there is a solution to this.
Hi @Booyah, welcome to the community.
If Xperia companion is not working correctly there are a few steps that you can try to resolve this.
Try these methods one after the other. Verify after each method whether the problem was solved, before trying the next one.
