Good day one and all.
Lately when I have the charger plugged in I am unable to use the screen and keyboard as it constantly gives wrong selection, for example trying to enter a search into my browser I might get 2 letters typed in then it will randomly enter many others or on start-up if I try to input my unlock code it will select multiple numbers. When not on charge I have no problems.
Not a real problem just very annoying.
Have you tried a different cable, an unshielded cable might be discharging a little current to the frame which may touch the digitiser and cause a small touch issue.
