WF-1000XM3 new update failing
djj081961
Downloaded new update,  it refuses to upload past 51% and now headphones useless.
can this be solved? or shall i return headphones under waranty?
Joe_Dohn
Specialist
That is peculiar, but thank you for sharing the update!
It'd be really helpful if you mark your last post as the solution so others can try your findings easily ^^
- JD
3 REPLIES 3
Joe_Dohn
Specialist
Try resetting them to factory settings then try again or try using a different phone to update it.
djj081961
sorted by deleting them from both phone and sony mp3  nw a105. reistall on samsung mobile only and do update.   no info about it finishing i should add.  delete off phone again then reinstall on mp3 and voila  working.   appears to be a clash between the 3 items.
Why though it should need almost 8 hours to do an update is beyond me!
Joe_Dohn
Specialist
- JD
