Hi, I have the above head unit and have installed a Pioneer PRS D800 Amplifier.
Ive attached the amplifier remote turn on lead to blue/white REM lead on the rear of the head unit, however im getting a Turn Off Pop when I turn the ignition off coming from the speakers.
If I remove the remote turn on wire from amplifier whilst the ignition is turned on and the music is playing, then I do not get the popping noise, therefore it would appear to be due to the Sony Head Unit switching off before the amplifier that's causing this problem?
Is there a fix for this as it's really annoying?
Many thanks
Hi, this sounds like a compatibility issue. nevertheless, did you try to check on whether if the device is on the latest software update or not? as on Sony's website there has been a recent software update for it:
https://www.sony.co.uk/electronics/support/mobile-cd-players-digital-media-players-xav-series/xav-ax...
