The Suction Cap, has, unsurprisingly, become detached and lost...!
Sony is unable to supply a replacement.
Does anyone know where I might get one?
@TheAdjutant If you're in UK, you can actually locate an authorised repair centre they can help you with that lost part: https://locator.sony/en_GB/servicecenters/?zoom=5&latitude=54.29088&longitude=-2.37305. Or I believe you can check that web for spare parts, but you need to have the part number: https://www.youritdelivered.com/
