New WH-CH710N
Alan1947
New WH-CH710N
Running Windows 7 - tp-link UB500 bluetooth 5.0 adaptor
loaded and installed driver
Headset paired successfully
BUT shows as a mono device!!
Any thoughts??
Sounds play but are quiet and definitely mono.
Help appreciated.
Could headset be faulty?
710N plays ok when wired connection.
Help
2 REPLIES 2
jfpena
Hi!
I´ve just bought a tp-link UB500 5.0 and my headphones don't even connect. They get paired, but when turned off and then on, they don't longer connect again (sounds like a click on left speaker).
What OS are u using? I'm running windows 10.
On the other hand, when the headphones connect, they sound stereo. I've tested then with a cellphone and on other computers and sound and connect correctly. Have you tried to pair them to a phone, to discard the issue of the tp-link?
I may give it a try with a tplink ub400.
HannahEd01
