August 2020
August 2020
wifi not connecting sony vaio VGN-NW24S
I have a VGN-NW24S. I switched of some startup programes and now do not see any network connections. Have switched on all the startup which I had stopped. Still no luck. Running Windows 7.Any suggestions
3 REPLIES 3
August 2020
August 2020
Hi Carlbharj,
You don't see the network icon or you don't have a network connection?
Maybe you accidentally disabled the WiFi switch:
Peter
August 2020
August 2020
Thank you for your message. The Wi-fi switch in the front is on and I have tried switching it on and off and then back on. I can connect with a hard wire but not wireless. May be the Wi-fi has been disabled and I need to enable it. Any suggestions on how I can do that?
Carl
Sent from my iPhone
Carl
Sent from my iPhone
August 2020
August 2020
Hi Carl,
Maybe you disabled the VAIO smart network function.
Can you check if it's enabled?
Else you might want to re-install this feature:
https://www.sony.co.uk/electronics/support/vgn-series-vgnnw200-series/vgn-nw24s/downloads/Z0000717
Peter
