VGN FZ210CE
knox102
VGN FZ210CE
i require all the drivers for my laptop as i had a HD failure, i kept meaning to create backup discs but kept putting it off :slight_frown: has anyone got a copy or a place where i can download them as i only seem to get patches and updates from the VAIO site.
Thanks
3 REPLIES 3
rich912
Contributor
Hi knox102 and welcome.
Did you purchase the VGN FZ210CE in the EU, as this would appear to be a USA/Canadian model?
If so you will need to check the US site for original drivers.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-FZ210CE
Go n-éirí an bóthar leat
knox102
I had the laptop imported into the UK when the Dollar was 2 for 1 so worked out cheaper, well until the import tax :slight_frown: i have looked on the US and CAnada website but all i seem to get is updates and no full driver downloads.
Thanks
rich912
Contributor
There seem to be a number or originally installed drives and utilities in the link I posted but possibly not the ones you require.
Unfortunately it would seem that recovery disks are no longer available for your model from Sony USA :slight_frown:
Click HERE for details
