I've had this LN1M for 2 months, and this is the first hardware problem I've had with it. Basically, tried to switch on my computer this morning and it came up blank but kind of flickering. Then noticed that the HDMI function was on, with the green light that's on the right switched on. I never use HDMI and have only turned it on once to see what the button did and then turned it off again, with no problem. Well, this time, there is a problem. No matter how many times I press that flaming button, the HDMI function will not go off, thus I cannot get into my computer. I have already tried turning the whole unit off, leaving it for 15 minutes and turning it on again, to no avail. HDMI is still stubbornly on. I can't even get the HDMI menu to come on screen when I press the relevant button, to see if I could exit it that way. The whole PC is on, and the memory light flickers when I press the keyboard, but nothing else is happening. I've tried doing alt+F4, and ctl+alt+del but as I can't see anything on screen, I suspect that's not going to help.
I really hope someone can help me here ASAP as I really need my PC back this evening.
Hello,
I have same problem.
I m french so excuse my english.
Did you have en answer? Did you fix it?
thanks a lot?
I got the same problem this summer. Resolved by HDMI board replacement in the Sony service. This is a well known problem for LN1M
