Hi all,
I have just purchased the all in one SVL2412Z1EB and I am struggling with setting up the TV function.
In the manual it says 'for details on the antenna conection, refer to the on-screen User Guide. However, when I check this user guide I can not see anything about the TV antenna.
Does anyone know if there is some in built antenna in this model that I have to switch on through some setting or do I have to plug in an external one?
Thanks in advance,
RP
Hi mahesh52 and welcome.
To receive digital television you will need to connect your Vaio to an external antenna - preferably one on your roof.
You need to connect the co-axial cable from the antenna (or the wall plug) to the co-axial socket on the back of the Vaio.
Thanks Blencogo, probably a very obvious question but thanks for the answer! will give it a go
