Hey there!
I bought in December 2009 a Vaio VGN-FW51JF/H. I bought a blu-ray and open it with the Intervideo WinDVD BD for Vaio, appears a pop-up saying that the color scheme must be changed to Windows Basic (which automatically the notebook does). When I see the blu-ray, the image is grainy, with colors a bit basic and does not look a Full HD monitor to play blu-ray. I've been to the site of the Vaio and did the update, but still appears the same thing. Is it a problem of origin or the image of blu ray isn't so good after all? By the way, the movie I tried was "The Fall", if they want to go see the images.
I would appreciate your help!
Thank you
Greetings from Portugal
Some bluray movies are grainy per default, like "300". Try a movie like wall-E then it should be crisp.
"color scheme must be changed to Windows Basic"
I both have Windvd BD and Cyberlink PowerDVD, both players cant handle the windows 7 aero theme while playing a BD. Thats why the color scheme changes to basic!
Thank you for the quick answer!
Sorry about the ignorance, but the fact that the color scheme changes to basic doesn't affect the blu-ry color while playing?
Thank you
"color scheme changes basic doesn't affect the blu-ry color while playing?"
No not at all. Its only the aero theme that changes nothing else. 🐵
