resolution problem with vgn-fw31j
lalaslaur
hi i have an vgn-fw31j with an problem on the display the white color has become pink and the black color has become green.What can i do to solve this problem? :devil:
3 REPLIES 3
rich912
Contributor
Hi lalaslaur and welcome to the forum.
The problem you describe could indicate that there is a cabling/inverter problem or that the screen itself is failing.
To narrow down the problem I suggest that you try attaching an external monitor (if that is possible). My guess is that the display will then be fine.
Go n-éirí an bóthar leat
lalaslaur
i put an external display and it is working fine.what should i do next?
rich912
Contributor
This would indicate that you have a hardware/cabling/LCD problem, but not graphics card related. If your notebook is still in warranty then raise a case with Support. Otherwise I suggest that you contact an independent repairer for a quotation...
