Problems with my vaio W-series netbook
Maluks
Hi all,
Just got a w series netbook. I set it up two days ago and each time i boot it, it goes on 'updating...'mode. its takes forever to open a window (i get up, make a cup of tea and come back and still wait :slight_frown: ) plus it also freezes all the time and the base gets quite hot within minutes. Is anyone else having these problems with this series and are there any suggestions on what to do?
Will appreciate responses.
Maluks
4 REPLIES 4
Thalamus.
Champion
Hi Maluks,
welcome to Club VAIO.. :slight_smile:
As your Vaio's new I would suggest your do a system recovery, using the Vaio recovery centre.
If the problem persists then either contact vaio support, the first thing they'll probably suggest is to do system recovery anyway, or return your vaio to the retailer.
Maluks
Hi Thalamus,
you have been most helpful, thanks a lot.
i suppose i need to get an external disk drive and save settings in order to do system recovery or buy recovery disk as i have not done this already. sorry to impose but what will be the best way to go?
Thanks a lot.
maluks
THEFORTRESS
omg omg , i'm having the same problems - issues as you did to .
my sony vaio W SERIES IS SLOW , IT FREZZES , TAKES A LONG TIME TO OPEN , START UP IS SLOW , PROBLEMS WITH WINDOWS AND INTERNET EXPLOER.
I'VE ALREADY HAD A TECH TO SERVICE IT AND HE AND I BOTH THINK , AND OR FEEL THAT IT IS
THE PROCESSOR !!!! I'M TAKING MINE IN BACK TO THE SONY FLAGSHIP STORE WHERE I PURCHASED IT AND HAVE THEM SERVICE MY SONY VAIO W -SERIES NOTEBOOK !!!
I'M SO MAD NOW .... DISAPOINTED AT MY NEW NOTEBOOK !!!, MAN .....
Thalamus.
Champion
Hi maluks,
You should be able to recover your Vaio back to the original installed OS and programs just as it was when you first used your Vaio using the idden HDD partition..
To do this Start your Vaio and when you see the Vaio logo screen press F10 repeatedly this normally would start the recovery process..
