I am unable to use the supplied power cable from the back of the PC to the APC backup unit as it has a European 2-pin.
The APC came with two cables but the connection to the PC are both straight. The orignial cable with the PC is right angled to allow the back panel to be fitted.
Where can I go to get a cable, surely there is a good place to try.
What is the name of the sockets on the APC which are the usual sockets on the back of a PC power unit?
It´s not easy trying to find and ask for an item when you don´t know the name of the sockets :smileyd_oh:
