Power control options
sunking101
Hi. Whilst running on battery power I find browsing the internet a much more enjoyable experience because my fan doesn't come on half as much. When I'm on AC power the laptop gets much hotter and there is more fan noise. I've tried to adjust the power options so that they're exactly the same as when running on battery power but it doesn't seem possible. Is there a way?
3 REPLIES 3
profile.country.en_GB.title
@5528097000005097
Sounds like your CPU is running on performance mode when on AC power, if so, change it to adaptive, that way, it'll only run flat out when it needs to.
sunking101
Nope, it's currently set to adaptive.
MattWilson
Do you have the battery in when you are on the mains?
The battery will be getting hot and making the fan turn on.
:slight_smile:
