Network Printing
kevintong86
Network Printing
My VAIO desktop is running in Windows XP and have been set up a home network with 2 laptop computer. All the setting is OK, file and internet sharing are also working properly. When printer in progressing, it's stop suddenly, and pause for a long time, sometime in 1 minutes, sometimes more and sometimes the printer was not response. I'm wondering how is that happen? Is this a setting or hardware problem?
My printer is Cannon BJC-1000, is the model too old for networking?
Please give me a hand, Thanks! :wink:
4 REPLIES 4
smsmasters
try going into the bios and set the parallel port to ecp mode. it worked perfectly for me on my sony rx 305 :smileygrin:
A-PaLm
also see inside device manager at lpt and com that the setting of the ecp is set to "use any interupt...."
kevintong86
Thanks for your help! I have made the change and see if it is working properly. By the way, did anyone installed the Win XP SP1? Have you got any problem after installed? :tongue:
smsmasters
i installed sp1 for windows xp home. it worked well. no problems so far. infact, i think my pc is a bit faster :smileygrin: :smileygrin:
