format a floppy
beano1966
format a floppy
hello
i have a Sony Vaio rx301 with windows xp
could anybody tell me how to format a 3.5 DD disk (720K) :smileyconfused::
When I try to format the disk I only have the choice of 1.44Mb
I changed the bios settings to 3.5 DD but then windows thought my floppy was a 5 1/4 inch drive
4 REPLIES 4
William
Sorry to sound pessimistic but I think the days of a 720 floppy are over.
Regards,
William
EzDoezIt
Open a command prompt and type "FORMAT /?"
This will show you how to format a 720KB diskette.
William
Hi Again!,
Sorry I had forgotten all about DOS although I can still remember avoiding Windows 3.1 for as long as possible.
In fact I tried to format a 3.5 inch disk using FORMAT A: /F:720 in DOS but it would not format perhaps because it had previously been formatted as a 1.44Mb.
I then tried Windows NT, this also had a facility to format a 3.5" disk as 720Kb but it also gave up.
Hope you have some previously unformatted disks as this may be the answer,
regards,
William
beano1966
thx
Format A: works and detects that the inserted disk is DD
