Connecting my PCV RX201 to my TV
fredb
I'd like to connect my Vaio to my TV (especially to see DVD movies).
So I looked for a switch or a plug on the rear of my Vaio's desktop so that I can connect my computer to my TV... but couldn't find it.
Is it normal ?
What are the solutions to connect my Vaio RX201 to my TV ?
2 REPLIES 2
profile.country.en_GB.title
robpaxton
I am pretty sure your computer doesn't have a TV out socket so you have several options -
1 - buy a new video card with a TV out socket
2 - buy a vga to tv converter
3 - buy a standalone DVD player
Personally, I would buy the DVD player. :slight_smile:
Regards, Rob
kee-lo_
Yeah, get a DVD player thats multiregion and plays DVD-Rs if you have a DVD burner from your VAIO, then you can watch your home movies you have created in DVGate.
