Hi - I bought the above set recently and have upgraded my Sky package for the 3D channel. Sky have turned the channel on but I can only see the split screens. I have tested the 3D samples on the telly but the setup notes that the TV finds 3D automatically. Am I doing something basic wrong? Any help appreciated.
Hi redexile591,
welcome to Questions & Answers..:smileyhappy:
Do the following steps help:
- Display the content to watch in 3D on the TV screen.
- Turn the 3D Glasses on, then put them on.
If no 3D effect is achieved, perform the following steps.
You can use the following models of 3D Glasses: TDG-BR750, BR250, BR200, BR100, BR50. (Availability of these models may differ depending on the region/country.)Power button
3D Glasses TDG-BR250
- Press the 3D button to display the [3D Display] screen.
3D
- Press the 3D button repeatedly to select the [3D Display] mode to suit the displayed content.
[Side-by-Side]: Displays side-by-side pictures in 3D.
[Over-Under]: Displays over-under pictures in 3D.
[Simulated 3D]: Displays regular 2D pictures in simulated 3D.Depending on the input signal or format, [Side-by-side]/[Over-Under] may not be selectable.
To exit the 3D Menu, press the RETURN button.
To deactivate the 3D effect
Press the 3D button repeatedly to select [Off] in [3D Display].
Hi redexile591,
3D
