pdgalaway
Sony Bravia 32/s3000
Can anyone help my tv for the past few days has had the channel number and when sky is on it comes up with the channel number and 1080i/50 i have gone through the settings loads of time.
Does anyone have any sudjestions. sorry for any spelling as i have brain injuries as a british soldier
thanks everyone
Anonymous
Hi there
Try pressing the i+ button on the remote control.  You may need to press it a couple of times as it cycles through other options.  I have circled the button in red on the picture below.
undefined
4 REPLIES 4
Anonymous
Hi there
undefined
pdgalaway
Thats great thank you for future ref if i cant find the remote to sort it is there away to do it on the main tv
Anonymous
I dont think so to be honest.  However, if you cant find your remote - you cant accidently press the i+ button to enable it, so...  (I dont believe it comes on automatically anyhow)
Im glad its worked anyhow.
pdgalaway
once again thank you
