KDL32W705C / iPlayer issue
BigBlueLou
Does anybody else have a problem with the iPlayer?
It remembers my sign-in details and I stay logged in.
It does not remember what I have viewed.
When I return to the continue wathing the series I as watching, it continues from an already watched episode.
1 REPLY 1
Sean_Mc
Moderator
Hi there,
Have you checked that you are using version 2 of the iPlayer app?
Please note that you will need to uninstall the old app first as the new version will not work correctly if you haven't uninstalled it.
If you are already using the newer version and still having issues, then I would recommend getting in touch with the support team for further help here.
Best wishes,
Sean Mc
