KDL-55HX75G and STR-DH520 compatibility (volume display)
Hello!
Just bought KDL-55HX75G television and connected to my sony av amplifier STR-DH520 with 1.4 HDMI cable, everything works good, only volume displays wrong on television and amplifier. when turning volume up with tv remote control, display shows soundsystem: volume + and value is 10. but on amplifier display shows value 8. Annoying bug. Volume value 3 shows correct on both, but when turning 1 up, tv shows 5 and av 4. and when turning volume even more up, the difference with values rise again on value 9 on tv, then av shows value 7. this should be easy to fix with program update on television firmware.
Another problem, television forgets time to time my wireless router when tv is turned off. When connecting again, sometimes reconnects with 1st try, sometimes have to wait an hour. Other devices stay connected.
Hi the volume numbers on products are not linked, your amplifier volume will differ to ever other product connected and in order to have the volume level match across different connected devices you may need to adjust each of them to have a single level via the amp, ie Sky or Cable box could be at 12, while. DVD player is set to 6, all different and have different controls, the TV volume indicator will not match any of them
