Hello,
I have a KDL-40HX720, together with a CMU-BR100 camera for skype. the TV is connected via an ethernet cable to the router.
I've tried unsuccessfully to login with two separate skype accounts, but after a long time on the "signing up..." screen, the tv goes right back to the Home menu. There is in fact a message appearing but for probably around 0.1 seconds, which I'm unable to read. The only word I could recognize was "Internet".
However, the error is not because of a possible lack of connectivity, since all other applications work - from widgets to file sharing in the home network. Therefore, I can't conclude it's because of the connectivity or incompatibility with the router (from Cisco if it helps).
The camera is well connected since when I disconnect it, the application does not even launch.
I also tried to do a Factory reset and also choose a different country on the beginning of the application - Czech Republic and US, which did not work.
Furthermore, the same behavior appears when I try to login using even a wrong password.
Couldn't find a similar problem/discussion here or on any other forum.
Thank you for your help
Hi miguel.amavel,
welcome to Questions & Answers..:smileyhappy:
Does the solution posted on by unhappyandy on the bottom of page 5 HERE help..
Hi miguel.amavel,
I am facing similar problem. Have you got a solution for it?
Microsoft has discontinued Skype on all TV platforms. See:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/138848
Also:
https://community.sony.co.uk/t5/the-lounge-room/skype-no-longer-supported-on-tvs/m-p/2184174
