BBC News not found
GELÖST
Ianls1
Neues Mitglied
BBC News not found
I have been using my KDL-24EX325 for a few years now and a few weeks ago the BBC News features suddenly stopped working. When selected it comes up with a white screen saying URL not recognised.
I have tried all the normal things with reboots,  updates etc but with no luck and I cannot see any thing in the news or web to help me. I KNOW the internet connection is fine as all the other options work including BBC iPlayer, it just seems that the News feature is broken.
Can anyone help or am I condemed to watch Sky News for ever more - urgh!
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Ianls1
Neues Mitglied
Yeah it's back! Thanks for the fix.
One small point: The pause botton no longer works, a real pain when someone phones you in the middle of you watching the news :slight_smile:
11 ANTWORTEN 11
dafoste32
Neues Mitglied
I am having the same problem and after resetting the TV back to factory settings the problem is still there. I would also like any answers anyone might have as we do use the BBC internet news often
Anonymous
Nicht anwendbar
Hi guys
@Ianls1  - The model number for your TV is not a UK model number - are you located in England?
@dafoste32  - Can you please provide the model number of your TV - This is important.
I have tested the BBC news application on my 2013 TV (KDL-42W807A) and it works fine.
Ianls1
Neues Mitglied
Quinnicus,
Sorry I mistyped its a KDL-24EX320 and yes I live in the UK and the TV was bought from Lakes in SLOUGH
Anonymous
Nicht anwendbar
Hi there
Thanks Ianls1 for the clarrification of your model number.  It is a UK model number and a 2011 TV.
I enquired with my contact with Sony today, at this stage there are no reported problems with either iPlayer or the BBC News app.  Ive been waiting for more people to report in with model numbers of TV's effected.
My mum also has a 2011 TV, and ill ask her later if she can access the BBC News app
Can you please do one more thing - It will make it easier to report and provide evidence to Sony.  Are you able to take a photo of the error message on the TV?
Thank you
Anonymous
Nicht anwendbar
Hi All
I have reported this issue officially to Sony for them to investigate (my mum came back to me to confirm on her 2011 TV)  Previously, similar issues like this (with iPlayer) was a BBC issue of which Sony has little control over - however Sony can liase with the BBC to get this matter resolved.
Any updates will be posted back in this thread.
Thank you.
Anonymous
Nicht anwendbar
Hi all
Just an update.  Sony has confirmed the problem in their testings.  They are now looking at the cause/solution.
Ianls1
Neues Mitglied
Anonymous
Nicht anwendbar
Hi there
Thanks for confirming that it now works.  Sony has also confirmed that it has been fixed.
Unfortunately Sony cannot do anything with the 'pause' button.  you might want to contact BBC in regards to that.
DanLeo4
Neues Mitglied
It sounds like the BBC News feature on your KDL-24EX325 is having a specific issue. Since other services like BBC iPlayer work fine, try clearing the app cache or resetting the TV's network settings. If the problem persists, it may be due to a change in the BBC's streaming protocol or a firmware issue with the TV. You might want to contact Sony support for further troubleshooting.
