Hello i have xperia x10 mini, and have synced my contacts in desired group on gmail, but... after 2.1 update, i'am not able to save my new contact in my desired group in gmail, but only in "my contacts" group, which i have to manually move in gmail from "my contact" group to desired group. Can i save my new contacts directly to my desired group and how?
I'll keep looking into it
thank you
anybody?...i still didn't find a way and it is really giving me a headache 😞
I've been investigating this and it seems that in Android 2.1 you can only select to store the contact directly on your Gmail account which means that the contact will be put in the My contacts group.
There's unfortunately no settings to change regarding this in the phone, and I'm not aware of any application that could manage this for you.
thank you for the help
