Xperia Arc dropping Wi-Fi connection
Just bought the arc for 3 weeks and found out that, the wifi always drop the connection and need to restart my router. In the office i could not restart.. what is the solution for this. I read discussion with lots of issues on this. Will SE solve this issue?
if you don't have the latest update go to settings -> about phone -> software update
also I would advice to backup everything on your phone
this is how
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
7 REPLIES 7
do you have android 2.3.2? or 2.3.3 or 2.3.4? also check the firmware
settings -> about phone -> android version and build number
this issue was fixed with the latest 2.3.3 and 2.3.4 udpates
this is how
or
How to install it
You need to
Contacts
open your phonebook
on your computer
Apps
SMS/MMS
or your SMS use
Call Logs
you can also use your PC and either use
PC Companion
or
Update Service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
or FlashTool (third party solution if your network hasn't released the update and/or if you want to debrand)
http://talk.sonyericsson.com/message/108770#108770
uli w!! thanks so much for the details answer.. updated mine and seems like no more dropping!! Slightly_smiling_Face
thanks!!
slimshaddy
Hero
great mark the thread as answered Winking_Face
Slightly_frowning_Face i think, the updates 2.3.4 does not 100% working. It can't connect to the wifi. Curently i'm using a laptop which is connected to the same Wi-fi .. Still the arc scanning-disconnecting .. feeling like to return it ... anyone can help?
slimshaddy
Hero
ok..go to settings > wireless and networks > wifi settings
there will be your wifi in wifi networks..long press on it and select "forget network"
it will again search for network..
when your wifi shows up.. select it..insert your password and see if it helps..
