As it says on the tin, I've deleted content from my drive (over 1gb) of data from my 8gb card, but it is not reflected in the system menu for the sd-card /storage. When i check the 'settings/ SD card & phone storage settings" it still claims i'm using xx% of the card with only 700mb free - when in fact I should now have closer yy% at nearly 2gb of free space.
Can anyone advise?
Hmmmm .... 'recycle bin'! that rings a bell!
Search for a folder 'LOST>DIR' in your SD Card, you can delete files in the Folder but DON'T delete that folder.
I guess the next best thing to do is to delete files using your phone, at least you don't have this annoying problem.
Hi Antimisandry, not sure if a phone reboot will help but give it a try.
Tried that - no joy, unfortunately.
No idea why .... is it reading the same when viewed from PC (connected to PC).
Yep
At first, it showed new free space - so i unplugged it and checked it against the phone's own claims. The phone said it hadn't budged - so I plugged it back in and although it originally stated it had more free-room, this time it showed the same as the phone's claims..
It's almost as if a logfile is being read and not updated (or overwritten by the old data/information).
The actual deleted data is still deleted.
Is there a recycle-bin type of thing i need to delete on the phone??
ETA: When I delete from within the phone (which is not practical for hundreds of images/short videos of my kids etc.) it reflects the changes correctly, i.e. if i delete 100mb of images, it shows free-space has increased by 100mb.
Thanks for the tip on which folder to look for... I'll give it a try.
However, regarding the 'use the phone to delete' idea, tht's fine - but i've still got hundreds of MB (or well over 1GB) missing and unaccounted for in the meantime
the LOST.DIR had 1gb of data in it.
I deleted it (using PC to test if it works) - and it's still reporting only 700MB free space
Reboot phone again, just try.
yep tried that already mate, no joy
