Updating phone software issue
I have an issue regarding updating phone software.
I used SE PC companion version, 2.0 and connected my phone using desktop using USB cable.
However, I cannot update my phone.
Is there any alternative ways to update my phone?
My phone:
SE Mini Pro SK17i
Android 2.3.3
Build number:4.0.A.2.368
10 REPLIES 10
you have the latest software already
Also, before you update or repair your phone make sure you backup your phone. Check my thread on how to do so
http://talk.sonyericsson.com/thread/20218
Don't forget to check the other Apps to backup your phone
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
It's weird that PC companion saying that new phone software is available while the update center is saying that my phone has the latest software. So which one I'm supposed to follow?
Thanks for your suggestion.
you can always try to re-check if there's an update
settings -> about phone -> software update
and try to check with Update Service instead of PCC
My Pc Companion Says there is a new update aswell i have the same version as you now.
A version 4.0.A.2.377 is ready to be installed it says but get a fault message when trying to upgrade
/Zastoff
