unable to use internet since upgrade to gingerbread
thanks
Hi there, i recently upgraded to gingerbread with no problems. however, since the upgrade, i have not being able to access the internet or use any internet based apps without WI-FI. can anyone help solve the problem? by the way does any one know how to get back that handy settings bar (screen two , the one where you could just click on the blue tooth, wifi, GPS and brightness settings without going thriugh the settings menu.
Uliwooly
4 REPLIES 4
Uliwooly
the power control widget is no longer available BUT you can install this
https://market.android.com/details?id=at.abraxas.powerwidget.free&feature=search_result
Uliwooly
regarding internet connection you can double check the settings
settings -> wireless & networks -> mobile networks -> access point names -> menu -> add new -> enter all the data
you can google the settings
android apn settings + name of your network
thank you very much, tried both solutions and they worked 1st time
Uliwooly
I'm glad its working now Slightly_smiling_Face
