Unable to send email from W8?
I am using sony ecrission w8 phone. I am not able to send any email
I am getting the following error message
The application Email (processcom.android.email) has stopped unexpectedly. Please try again.
Thanks & Regards,
Kishore Kumar
Jake-SonyXperia
Champion
I suggest trying the following to resolve the issue,
Menu > Settings > Applications > Manage Applications > Menu Key > Filter > Filter All > Email > Clear data.
This will remove data from the email account and in turn you will need to setup the email again on the handset, however this may resolve the problem.
1 REPLY 1
Jake-SonyXperia
Champion
