I have downloaded the update,updated the play app and when i launch the game it says"sorry having trouble playing this video"?? Anyonbe else with this problem.Also I cannot remove it and try a new download of it.Help if possible? Thanks
ill try it again....
nope,it doesnt have that in the lower right hand corner.
I believe that a video file in Star Battalion is missing or damaged. I think the solution to this might be to clear this folder: PHONE CARD:\games\com.gameloft.android.GAND.GloftStsq.ML
And then start Star Battalion again. Now the game will have to download all data again.
Note that by doing this you'll loose your save games for Star Battalion.
when u say "clear" this folder do u mean to delete the folder altogether? Or is there a way just to clear it? thanks. I have that folder right in front of me,just want to be sure which way i should go.
Try to just delete the whole folder.
Then start the game again to download it's additional data.
ok here goes....so far it is downloading the info again....fingers crossed
Nope,it says the same thing,sorry video cannot be played.i have contacted gameloft and already have 1 response from them.Hopefully they can fix it or something?? thanks for ur help!
Gameloft said that there is nothing that could be done because the game was pre-installed.So they gave me 2 games in compensation.Im sad that I wont be able to play StarBatallion but the games I received are awesome!!
