i have been playing with adding shortcuts to the home page of my phone and i no longer want them. how do i remove them???? been playing for ages.
long press on the icon/widget until it vibrates then drag it to the bottom center (trash can) it wont delete the app, it will only delete the shortcut to the homescreen/launcher
thanks very much
also I don't know if you have the latest firmware 2.3.3
go to
settings -> about phone -> android version
if you don't then
on your PC install PC Companion or Update Service to check if there's an update available. Make sure you backup everything before hand
you can see how to backup your phone here
if the update to 2.3.3 it's not available on your country/network you can install it manually
this is how
