Hi people,
I have this problem when I use PC companion to do the update. Everything goes fine until the 2nd step, then I get an error message saying: "unable to install phone update componenets' (or something like that). Anyone has this problem?
forget about PCC use Update Service
and if you still have an error then reboot your computer on safe mode then run Update Service
Hey uliwooly!
Thanks a lot for the suggestion. I tried Update service instead and it worked!!!! Seems like PCC is redundant then haha. I also feel that PCC is lousy for transferring files. Do you reccomend using media go or media sync? Which is better?
Anytime
Don't forget to try My Phone Explorer for both your PC and Android
Also Bluetooth File Manager
https://market.android.com/details?id=it.medieval.blueftp&feature=search_result
or if you don't want to deal with wires and bluetooth try DropBox
https://market.android.com/details?id=com.dropbox.android&feature=search_result
Ok Thank you! I'll try them soon
let me know if you need more help
