phone as modem
phone as modem
Hi I am trying to use my C903 as a modem , my phone connects fine to my computer using Sony Ericsson PC Companion 2.0 and does log on to the internet via my phone but when I visit a webpage the page does not load. the signal on my phone is ok .any idea's on why it is not working ?? thanks Dawn
Dr_Chris
Champion
This might sound pedantic, but two things to check:
1) Main menu--Settings--Connectivity--Internet & Streaming settings: Here make sure that the Allow local conn is set to Yes, as this facilitates local connections including USB.
2) Also under Connectivity--USB--Advanced--Internet Access--make sure this is set to Internet via Phone.
3 REPLIES 3
Dr_Chris
Champion
Hi thanks yes the tried the 2nd USB option it is now working , thank you Slightly_smiling_Face
Dr_Chris
Champion
No worries.
